Подскажите какая компрессия должна быть на 4G94 MPI, у меня 11.2 во всех цилиндрах. судя по википедии
he 4G94 is a 2.0 L (1,999 cc) version built in Japan, used in the Mitsubishi Lancer. It has a cast iron engine block with MPFI (fuel injection) and an aluminum SOHC cylinder head with forged steel connecting rods and four valves per cylinder.
4G94 SOHC 16 Valve MPI
Multi-Point Injection (MPI)
Total Displacement - 1999cc
Bore - 81.5mm
Stroke - 95.8mm
Compression Ratio - 9.5:1
Maximum Output - 92 kW (125 PS; 123 bhp) @ 5,200 rpm
Maximum Torque - 176 N·m (130 ft·lbf) @ 4,250 rpm
The 4G94 Also comes in the GDI DOHC variant which can be found in the Mitsubishi Galant.
непонятно, у меня больше чем должна или как?
